![]() | Home > Maintenance & Mods (L405) > L405 Seat Swap Nightmare |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 256 ![]() ![]() ![]() |
Has the seat module been coded to your car?
ChrisK Member Since: 16 Aug 2025 Location: East Yorkshire Posts: 5 ![]() ![]() ![]() |
Thanks for the information, really appreciate the help.
Do you have a G3iid gap tool? |
I take it your original seat modules don’t fit?
I haven't got a G3iid gap tool, I'll take a look online and see where I can get one.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8820 ![]() ![]() ![]() |
Sure I've read that they work on different can bus types and you can't make the early Range Rovers accept the later seats....
I contacted Land Rover and was told that it is possible, but some "tweaking" (as they put it) would be required with the wiring. I've done quite a bit of digging online and it was suggesting the same.
That's good news, can you share how it's done when you sort it out... Cheers... |
Hi Pete, absolutely! It's back from the paint shop early next week and we'll be cracking straight on with it, once we're up and running I'll share info/photos. |
5c0tty Member Since: 07 Sep 2015 Location: Long Buckby Posts: 28 ![]() ![]() ![]() |
Hi Chris
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 270 ![]() ![]() ![]() |
Would the simpler route not to swap the covers/cushions/trims over? Or was it a problem with that which made you go for the new ones? |
