Home > Maintenance & Mods (L322) > Chassis Rail Issue
Jonester
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Chassis Rail Issue
Hi all
New L322 owner just finding my way.
I just jacked it up to get the wheel off and I noticed that where I’d placed the axle stand has deformed slightly. I’d read axle
stands could be placed under the chassis rail so my first stupid question is is this the chassis rail?
Post #722949 16th Aug 2025 4:54pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
L322s are monocoque, they don’t have separate chassis that you can place an axel stand under. You need to use one of the four jack points, rear subframe mounting points or on the other very specific locations described in the workshop manual - have you checked out the wiki? 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #722956 16th Aug 2025 5:49pm
pcourtney
hope this helps, and lots more info is on the forum ( use the search - thats what it is there for) Smile
https://www.fullfatrr.com/forum/post307204.html
Post #722958 16th Aug 2025 6:30pm
Jonester
Between forums and YouTube videos there must be well over 30 different THE “definitive” way to place axle stands on an L322 with acrimonious debates over the various approaches, never seen anything like it. But I guess that’s Range Rovers.
I’m thinking the simplest way is to jack from the front/Rear and place stands on the jacking points. Not seen the wiki but now that someone has pointed out the search feature I’ll have a look for it.
Thanks for the tip.
Post #722965 17th Aug 2025 6:57am
Jonester
I was looking for a search box, don’t realise it was just just just “click on the word search”. lol
And thanks for the diagram, that’s helps massively.
So I guess when I’m seeing people jacking from the front and the rear to save jacking each side independently this isn’t an “official” jacking point. lol
Post #722966 17th Aug 2025 7:01am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
What you see in the diagram above is the official way because you’ve seen what can happen when you use the ‘chassis’ rail as an axle stand support….. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #722967 17th Aug 2025 7:14am
pcourtney
The Sealey trolley jack you have needs the correct shaped adapter to fit into the rectangle shape jacking points on either side of the car, if you don't - then its very easy to move and create more damage
https://www.fullfatrr.com/forum/topic14177...ottle+jack
Post #722979 17th Aug 2025 9:50am
Jonester
Quite.
And I’m definitely learning that there are lots of people posing as Range Rover experts on social media who haven’t got a clue what they’re talking about: the recommendation for jacking/axle stands on the “chassis rail” is pretty widespread.
Post #723008 17th Aug 2025 3:29pm
Jonester
pcourtney wrote:
The Sealey wheel jack you have needs the correct shaped adapter to fit into the rectangle shape jacking points on either side of the car, if you don't - then its very easy to move and create more damage
Many of us have Mercedes Sprinter bottle jacks with an adapter - this is what I am referring to
This is how my trolley jack came as standard. That ok or wrong shape?
Post #723009 17th Aug 2025 3:33pm
pcourtney
your Sealey trolley jack is fine, all trolley jacks use that style of pad, but it really needs an adapter, basically something made of metal that slips over the trolley jack and the rectangular bit at the top is shaped to seat properly into any of the jacking points on the car
Post #723011 17th Aug 2025 3:46pm
