![]() | Home > Maintenance & Mods (L405) > Tailgate Stay - Caught it early |
firstrr Member Since: 27 Sep 2024 Location: Lancashire Posts: 37 ![]() ![]() ![]() |
Very good advice.
sullivj Member Since: 19 Jun 2025 Location: Gatwick Posts: 57 ![]() ![]() ![]() |
Is it possible to separate the ball and socket in situ..? |
Well mine had disintegrated - including the spring steel retainer that is attached to the end of the actuator which you can see if you zoom into the picture of the new one below. When I fitted the new one it was a case of grease then press the socket onto the ball (hinge).
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1877 ![]() ![]() ![]() |
Yes, this is a very common thing to corrode on the L405, there is also down to the left, at least on my MY2017, a completely unpainted bolt which gets very rusty. I replaced with a new one wich I painted before replacement. I recommend checking a couple of times a year and applying ACF-50 or Lanoguard grease or similar. V6 Vogue - “Less is More” - less to go wrong! |
bigdave Member Since: 27 Jun 2011 Location: Cornwall Posts: 274 ![]() ![]() ![]() |
Hi Gremlin500,
If it’s M8x30, then LR037087, plus a can of touch-up. V6 Vogue - “Less is More” - less to go wrong! |
Thank you good Sir. |
Do you know the part number for this item please? |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 280 ![]() ![]() ![]() |
I think it is LR034445
Yes confirmed as part number LR034445 Actuator
