Home > Maintenance & Mods (L405) > l405 lower control arm torque settings
jeffshaw
2015 Range Rover Autobiography SDV8 Balmoral Blue
Would anyone know the torque settings for the two lower control arms. TIA
Post #723208 21st Aug 2025 6:49pm
nike_bytom
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Attached:
 L405 4.4 Vogue
L538 2.2 Prestige
Pozdrawiam
Rafal
Post #723246 22nd Aug 2025 10:00am
Gremlin500
At normal ride height, remember. V6 Vogue - “Less is More” - less to go wrong!
Post #723249 22nd Aug 2025 10:13am
remember doing the equivalent arms on my 322, to obtain "normal ride height" I think I had to do the bottom ball joint nut first then put a trolley jack under the hub and jack it up to road height measured in relation to the arch from the centre of the hub. its pretty much the only way to do it if you don't have a ramp as getting enough room to swing a long bar to 100Nm and 360deg under the car in normal height is tricky..... There is nothing that can't be fixed with a hammer😜😜
Post #723700 31st Aug 2025 12:22pm
