![]() | Home > Technical (L322) > 5.0sc cranking a long time before starting (occasionally) |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 781 ![]() ![]() |
Have the LPG injectors been serviced recently?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1403 ![]() ![]() |
What cass said will most likely be the issue, once the temperature drops and no sun on the bonnet, it'll probably dissappear.... |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
I had a similar issue on my 4.2. It wasn't an LPG injector leaking though, it was the LPG reducer. The diaphragm inside the reducer had failed so it was filling the vacuum line and inlet manifold with LPG when the car was switched off so it had to crank for a long time before starting.
Super7 Member Since: 23 Feb 2019 Location: Somerset Posts: 28 ![]() ![]() |
Thanks for the advice everyone, I will have a look through the lpg system and get the injectors serviced, I know the vapour and liquid filters were changed a while back but I'm pretty sure the injectors were not serviced.
Morning everyone,
