![]() | Home > Technical (L405) > SDV8 EGR valves |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 235 ![]() ![]() ![]() |
fairly straight forward, i removed the EGR and cooler for my issue (long story) there is some hard to reach / not much room bolts on the back of the egr that bolt below the crossover pipe i used a short ratchet. ill try send you what i followed, steps 17 - 20 show the bolts mention above
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
A very good chance!
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3392 ![]() ![]() ![]() |
“ I’ve noticed that the eyes have started to get a bit noisier when you shut the car down?” - are you sure it’s the EGR valve? The throttle plate goes through a few open and close cycles on shutdown to free off any soot buildup and this can be quite noisey. 2012 TDV8 Vogue (L322) |
not had a chance to look into it over the weekend. But it's on the job list for the coming week. get the bonnet up and have a listen and a poke around to see what is making what noise!
