Home > Technical (L322) > oil cooler question
latteLarry
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
oil cooler question
Hi all, i have a few questions.
I'll be looking to replace the oil cooler on the 4.4v8 over the coming week, and after reviewing the wiki page and others, there is mention that a coolant hose junction generally snaps off as it's a known weak point (sorry, i don't have a photo).
Could anyone advise me on the part code for the hose branch piece?
Do I need to drain the cooling system before removing the cooler?
Should a new cooler come with related gaskets?
And where can I get the turbo feed pipes o-rings?
Any help greatfully appreciated, and I'll post pics of the expected gunk when I'm done 2011 4.4 Vogue, Santorini
Post #723399 25th Aug 2025 12:43pm
mjdronfield
Don’t have part number to hand, sorry, but you will have to buy the connection and associated hoses, you can’t get connected separately. Around £100 I think when mine snapped. It’s at top of engine at front…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #723402 25th Aug 2025 1:37pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #723403 25th Aug 2025 1:40pm
mjdronfield
LR029140
https://www.fullfatrr.com/forum/topic51406.html?highlight=coolant 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #723405 25th Aug 2025 1:56pm
PeteT80
The O rings are Viton BS611 - 8.73mm ID x
1.78mm. And are available from a well known auction site
Post #723414 25th Aug 2025 3:22pm
latteLarry
Thanks both,
I'll make sure I get these on order.
Do I need to drain all of the coolant to avoid mixing? I am planning on an oil change as well 2011 4.4 Vogue, Santorini
Post #723417 25th Aug 2025 3:44pm
