Home > Technical (L405) > lower arm nut size
28capridave
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
lower arm nut size
Hi does anyone know the socket size for the nut on the front lower ball joint to wheel knuckle and the nut of the rear lower ball joint to wheel knuckle at all it looks to be something like 40mm but multi splined.
TIA dave.
Post #723406 25th Aug 2025 1:58pm
Gremlin500
The 12-point nut is 36mm, the other end of the same arm is 17mm hex.
Not sure if I understood you correctly tho’. Embarassed V6 Vogue - “Less is More” - less to go wrong!
Post #723410 25th Aug 2025 2:45pm
Gremlin500
You might find this thread useful:
https://www.fullfatrr.com/forum/topic67045...lower+arms
Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #723412 25th Aug 2025 2:49pm
28capridave
Thats great many thanks, the steering knuckle has just snapped revering into my drive (luckily)
Cheers Dave.
Post #723421 25th Aug 2025 4:43pm
