![]() | Home > Technical (L405) > Rear suspension low with trailer |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 251 ![]() ![]() ![]() |
Has it been coded to stop it dropping?
Flash Member Since: 09 Jan 2025 Location: Stockholm Posts: 35 ![]() ![]() ![]() |
With the trailer hooked up the rear is constantly 3cm low both on the move and standing still. My Disco 4 always levelled off at the same height regardless of load or trailer.
Well it should level so get the codes looked at, hight sensor probably. |
How would an issue with the height sensors only materialise when the trailer is hooked on? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
What does your 4x4 info screen show? Is there a difference between loaded and unloaded? That shows the height sensors…..
I recalibrated the suspension with my GAP today and it turns out it was more than 10mm to high in the front more than 10 mm low on the right rear wheel. Will be interesting to see what happens next time I hook up the trailer. |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 224 ![]() ![]() ![]() |
I regularly tow a cattle trailer with stock so 3 ton + behind the L322 and the suspension height never changes much, once hooked on the suspension levels itself and off we go. I did calibrate the suspension after I bought an IID3 tool and that showed differing heights on every corner, (not that I ever noticed) reset the heights and since then it has all been fine. |
