Home > Technical (L322) > New key for 2007 L322= New Problem
sherman
France 2007 Range Rover Vogue SE TDV8 Java Black
Hi All, hope youre well
2007 3.6TDV8 Vogue SE
This is a new thread that doesnt seem to have been covered before. Ive checkedall the threads on new keys and cant find this problem anywhere, so here goes.
Got a new key from Duckworths, (thankyou for the discount!)
Used the threads on here to code the new key to the doors. No problem, (thankyou for the threads!). All 3 keys now open and lock the doors, but the new key wont turn in the ignition.
SUGGESTIONS?
Could it be that the new key has no power and needs to sit in the ignition to draw some power?
Could it be that it needs coding to the ignition with an IID tool?
Any thoughts and suggestions much appreciated.
Many thanks
Sherman 2007 TDV8 VSE Java Black
1994 MX5 1.8s softtop customised VW Diamond Black SOLD
1995 Mini Cooper 1.3SPI
1974 MasseyFerguson145 with loader
1968 McCormick International (under restoration)
Post #723597 29th Aug 2025 1:04pm
dingg1
2007 Range Rover Vogue SE 4.2 SC V8 Stornoway Grey
Chip needs coding to the immobiliser, should be able to do it with the iid tool
If you send pat at iid an email he should be able to give you an idiot guide to follow, I tried with an aliexpress key, couldn't make it work but a land rover original will be doable 👍
Post #723616 29th Aug 2025 7:57pm
