![]() | Home > Technical (L322) > wheel |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
when you start the range the steering wheel should go to a pre-set position, when you switch of the engine the steering wheel should re-tract and go up ..
tolley Member Since: 29 Aug 2011 Location: gloucester Posts: 99 ![]() |
thanks scarey
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Losing the steering wheel up and down movement is quite common, try using the search facility on this forum to find out what's involved in repairing it.
yes it might be costly to fix,tryed the height when stationary but no joy so that might need fixing. |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Mine had the same problem but I got it fixed under warranty. Garage said it cost em 900quid for the part they needed to fix it FFRR TD6 HSE
I THINK I MIGHT GIVE THIS ONE A MISS |
Or if the car is being sold by a garage either get them to fix it or ask for money off so you can fix it. FFRR TD6 HSE
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Sounds way over priced for an 04 anyway, I'd either go for a facelift for maybe a little more money, or look at 02 onwards, probably one or two good ones advertised on here! 2012 SDV8 Vogue SE |
Do you think so i thought it was not to bad.
just found another 04 69th 13800 vogue FSH landrover.
Well as a guide I paid £12900 for my 05 pre-facelift td6 vogue with 125k on the clock, and full lrsh. Fair enough the boot smelled of dog, still does a little until I steam clean it, and the lower tailgate wiring and solenoids were shot but it just takes good hunting down, specially as I don'tind doing a bit of work to get it A1 again |
Lower miles will mean a higher price FFRR TD6 HSE
