Home > Technical (L322) > 2007 L322 3.6 TDV8 Vogue - Stuck in Low Range
j4ck100
Good afternoon all,
I recently purchased an L322 3.6 TDV8 (Vogue) which has unfortunately gotten stuck in Low Range mode. The lights on the selector switch are just flashing red and pressing the highway button seems to do nothing.
I had to have the vehicle recovered as this happened 400 miles from home.
I am getting the error messages 'transmission failure', 'HDC failure' and the terrain control system is inactive too. The low range light flashes green.
Everything else seems ok and the gearbox moves through the gears in Low Range mode just fine.
Could anyone advise on how I might be able to rectify this?
Thank you
Post #723867 3rd Sep 2025 3:55pm
pcourtney
try disconnecting the battery for 10 minutes to reset the transfer box ECU, or perform the Fuse 37 trick by temporarily installing a fuse in position 37, then cycling the ignition and gear selector.
If these don't work, check the physical connections and linkage to the transfer box for obstructions or damage, and consider manually moving the transfer box lead screw if safe to do so.
Post #723892 3rd Sep 2025 8:44pm
pcourtney
did you by chance spill some drink near the gearbox lever ?? where the drink bottle holders are ....
Post #723893 3rd Sep 2025 8:51pm
dhallworth
This happened to me on a 4.2 Supercharged and I ended up having to replace the transfer box.
If you have an IID tool, read the fault codes, then look at the live values and see if it's registering a bottom press when you try and change it back to High range. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #723900 3rd Sep 2025 10:01pm
j4ck100
Thanks, no drinks spilt to my knowledge.
Will try the battery disconnect trick tomorrow.
Where did you get a replacement transfer box from?
Best,
Post #723907 3rd Sep 2025 10:59pm
