![]() | Home > Maintenance & Mods (L322) > 5.0 SC Timing Chains |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 690 ![]() ![]() ![]() |
Hi, quick question for those in the know and been through the timing chains issue on the 5.0 SC. I've been through the various threads but I've not found a black & white answer,
AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 60 ![]() ![]() ![]() |
Mines done approx 90,000 miles (not a typo 😁) since it had a new engine, apparently with the upgraded internals.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8785 ![]() ![]() ![]() |
The chain was replaced as it had non hardened guides in, not because it wears out all the time...
Many thanks for that, much appreciated.
Just out of interest is there a point in time where this stopped being an issue, i.e. the problem was fixed at the factory ?
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 637 ![]() ![]() ![]() |
I understand it was done by time of the change to the L405 so 2013 on factory fit should be good. Mike - MPx
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 988 ![]() ![]() ![]() |
That's good to know |
gt40 Member Since: 30 Jan 2013 Location: Cape Town Posts: 32 ![]() ![]() ![]() |
Unfortunately this is not entirely correct. In 2013 a redesigned tensioner / guide system was introduced but it did not include the hardened steel button. The tensioner plunger was changed from a stepped end to a flat end and the moveable guide has a slightly widened portion to accommodate the new plunger. The steel button design was only introduced in late 2014 after which time the guide wear problem was no longer an issue. So the 2013/2014 and some early 2015 cars do still suffer from wear on the guide but at a slower rate due the the wider plunger end. The photos below show the original and first redesigned guides and all three tensioner designs. (Not shown is the latest guide with the steel button). Note the bolt position of the latest tensioner design has also changed.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 406 ![]() ![]() ![]() |
That's all great info everyone as I'm considering a 5.0SC after 3 happy years with my 4.2SC
Hi, this is all positive news to me to be honest, it's not scaring me off.
