Home > Maintenance & Mods (L405) > 5L cooling tubes
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
5L cooling tubes
My SV is using coolant about 1L in a 1000 miles.
No sign of any leaks so will use a leak detector dye.
Planning on changing all the plastic parts under the super charger for the aluminium parts.
Anyone on here done this?
63000 miles.
Post #724128 7th Sep 2025 5:02pm
Mikey
Replace them for aluminium parts where possible
Y-piece, top pipe, coolant crossover pipes at the rear, oil cooler
Post #724130 7th Sep 2025 5:46pm
zenman63
Is it worth doing the water pump and connecting tube and belts.
Supercharger coupler and oil change?
Post #724131 7th Sep 2025 5:56pm
Inigo
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Corris Grey
I'm slowly gathering parts for this. I have the genuine Y-piece and top pipe from the V8 Defender. Are the others available in aluminium from LR or are there only versions available from thrid parties? Suggestions from other forums are that the unofficial parts aren't particularly great fitting.
Post #724135 7th Sep 2025 8:13pm
zenman63
Interesting the defender went back to aluminium?
Post #724137 7th Sep 2025 8:33pm
Mikey
Be prepared for there to be more wrong as you strip down Laughing
My 5.0 Sport spat it's water pump. So new pump and joining piece (and seals and gaskets) ready for a Saturday morning
Belts off, and the supercharger coupler had a load of play in it. So supercharger off. The symposer was a Censored to navigate around, so that was swiftly binned, and blanked off
Then a new oil cooler, and rear coolant pipes while your in there
New coupler fitted and a smaller supercharger pulley, because it'd be rude not to Wink
Oil change in the supercharger too, because you may as well, while your in that far Rolling Eyes
Edit: wrong picture. That's just the symposer down the rear of the engine, and a single vacuum pipe (and a blanking plate not pictured) to remove the whole thing and make future maintenance much simpler
Post #724138 7th Sep 2025 8:50pm
zenman63
Well it’s very common apparently, and Land Rover have gone back to Aluminium.
Part numbers LR186859 upper crossover
LR186917 y pipe.
Just asking parts for availability.
Post #724195 8th Sep 2025 7:32pm
zenman63
Update on this as it’s now showing its ugly head.
UV dye showing no leak on engine even with a bore scope, possibly a tiny mist on engine all over so a new pressure cap for that.
However water on the drive now, drivers side rear.
So now need someone who has done this to quote on dropping the rear subframe etc and replace the tubes.
Post #725512 2nd Oct 2025 5:38pm
Boatmechanic
Sweden
Did it a couple of weeks ago
I bought an aftermarket kit with lots of stuff from the US, and did the replacement based on a crappy pair of YouTube videos. Service manual was not very helpful.
My original plastic pipes looked perfect after 90000 km, so I only replaced the front and rear crossovers and put the remaining parts aside. Wanted to avoid trying to fix what wasn’t broken.
Biggest pain was the stuff behind the supercharger. Second biggest was installing the supercharger.
Feel free to ask any questions.
Post #725620 4th Oct 2025 9:03pm
Mikey
If you need to drop the rear subframe to replace those pipes, also consider doing the ARC + AC pipes at the same time...
Post #725645 5th Oct 2025 2:10pm
zenman63
Hi ,yes I will drop the subframe and the tank and change the rear pipes.
Looks like salt damage, way more than my old 16 plate 4.4.
I will try and get the tank guard hot galvanised as well.
Post #725649 5th Oct 2025 2:55pm
pretty sure that Craig did a thread on the rear AC line fix somewhere.... There is nothing that can't be fixed with a hammer😜😜
Post #725664 5th Oct 2025 7:14pm
