SOLVED : HELP! - Tow bar wiring connectors | |
I picked up a second hand tow-bar on e-bay for my 2009 L322.
 | Click image to enlarge |
It came with a 13pin plug and harness, but without a towing module. The loom has two plugs, a fuse holder and a relay.
The connection for one plug is easy :
But the other plug does not correspond to the format on the Towing Module (purchased separately)
Obviously not compatible. I have had a browse through as many threads as I could find, but no luck so far. I would be grateful if any one could tell me what I am missing.
On a different note, I found this while digging a round in the boot
Solution :
I was watching youtube videos, and found one of a guy fitting a Britpart harness, with a totally different controller, and the plug on the harness matched mine. A bit more research and it turns out that the harness originally came from Right Connections. All I have to do now is find the correct controller, and sell the OEM one I bought on e-bay
and remove the tracker.......
