![]() | Home > Technical (L405) > RR L405 Noise |
1JBS Member Since: 18 Feb 2014 Location: Henley on Thames Posts: 175 ![]() ![]() ![]() |
Check your roof trims not the sunroof ones but the car colour coded ones, these are stuck on with sticky foam pads, these can come unstuck over time, if they do the trim will rattle in that area as it has pins that drop into the roof bar sockets. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
If your sunroof drains are broken, ie the metal pipe has rusted off this could hit parts of the inner metal sunroof frame, easy to check, search on here on checking them and see if you get two wet patches inboard of both rear wheels...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
undo the grab handle screws and gently pull down the rubber trim and see if theres anything loose under the headlining. ... - .- -.
