Home > In Car Electronics (L322) > Logic 7 Amplifier battery drain
Bellhouse
Sweden 2008 Range Rover Westminster 4.2 SC V8 Java Black
I have a 2008 Range Rover L322 4.2 Supercharged Westminster with the Logic7 audio system (amp part no. XQK500105).
I’ve been chasing a parasitic drain issue and finally tracked it down to the amplifier.
With fuse F9 (30A – Audio system amplifier) in place, the car draws around 0.8 A at rest.
When I remove fuse F9, the draw drops to ~0.4 A.
If I leave the fuse in but disconnect the main power connector on the amplifier (red + brown wires), the draw also drops back to ~0.4 A.
So the amplifier itself seems to be staying awake all the time, even when the car goes into sleep mode.
Has anyone experienced this with the Logic7 unit?
Is it always a failed amp that needs replacing, or could it be triggered by another module (MOST, Bluetooth, nav unit etc.) keeping it awake?
Has anyone successfully repaired these amps, or is replacement the only real solution?
Thanks in advance for any advice!
Post #724556 14th Sep 2025 8:57pm
dash1995
2011 Range Rover Autobiography 5.0 SC V8 Galway Green
Pretty sure we are in the same boat. About 90% positive my amp failed and I have a parasitic drain as well. Some mornings I have a low voltage warning and whenever I leave the car unlocked with the doors open it just constantly whirs with the fan on.
Post #724563 14th Sep 2025 10:26pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Check for possible water ingress in the electronics bay housing the amp.
Inside the left hand (viewed from the rear) rear loadspace access hatch.
I had a similar issue with my erstwhile TD6 due to failed seal in the rear wash/wipe motor.
Had to replace the amp as well as a section of the cable harness SadSadSadSad
Can also be caused by failing seal to rear quarter glass.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #725251 28th Sep 2025 9:08am
