![]() | Home > Maintenance & Mods (L322) > Rear bags |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3366 ![]() ![]() ![]() |
Any problems with leaks or signs of the airbag rubber deteriorating around the main fold area?
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 619 ![]() ![]() ![]() |
Think mine are original 2005......leave until i hear hissing |
When I replaced the fronts which had 'perished'
Rudyard1 Member Since: 15 Nov 2021 Location: Devon Posts: 117 ![]() ![]() |
Thanks for the replies - I may just leave them alone and change the dampers. Bags are original and look to be pretty stout! 2007 Range Rover Vogue 3.6 TDV8 |
IMissNimoy Member Since: 08 Aug 2025 Location: US Posts: 6 ![]() ![]() ![]() |
All the air suspension in my 2011 is original to the car. I just examined front and rear suspension this week. Front looked similar to the pic in the above post, albeit not quite as bad. The rear bags have no cracks, but both dampers have leaks. So, same as you, I'll just do dampers. 2011 L322 HSE Lux 5.0 NA |
Minor fluid seeping from CVD rear shocks is normal and not a sign of failure or a need for replacement. 2012 TDV8 Vogue (L322) |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3339 ![]() ![]() ![]() |
I replaced them on my old 2007 L322 with Bilstein. I never had any problems with them but I've seen others saying that the bags are too short and tend to cause trouble if you put the car into off-road height.
AFAIK it’s only the later cars with CVD shock absorbers which cause a problem with some air bags. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2757 ![]() ![]() |
Longer shocks were fitted to MY07-MY09 TDV8 but they weren't CVDs. L405 D350 SE Carpathian Grey D5 19" rims |
I’m acutely aware that as I am now in possession of a early type rear sub frame for 2007 RR that am I going to have to replace the rear arms, suspension, toe links, ride height sensors etc to retrofit?! 2007 Range Rover Vogue 3.6 TDV8 |
Not trying to hijack the thread but since OP mentioned dampers and @JayGee said minor fluid was normal..... Mine are original 2011 and look like this.
