Home > Maintenance & Mods (L405) > L405 4.4 SDV8 Heating Woes - Help Please!
NorthernChap
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Hi all, I’m hoping that you wonderful bunch can help me with an issue that I’m having. My recently acquired L405 is refusing to produce heat into the cabin. Initially when I picked it up, it was getting warm/hot on the drivers side but the passenger side would progressively get colder the more the vehicle was driven. Having had a similar issue in the past, I decided to buy a changeover valve for the FBH and replace it (I replaced this on my previous 405 and it resolved the issue in an instant). This time round, it’s made the issue worse. Initially, I had stone cold air from all vents even when the vehicle reached normal operating temperature. Over the course of the weeks, I’ve convinced myself that it’s got an air lock and repeatedly tried to bleed air from the system (parked up a hill with the nose in the air) and boy, there’s tonnes of air coming out and it doesn’t seem like it’s going to stop! Today, after lots of bleeding and holding the revs at 2500k, I started to get warm air from all vents - front and back. I let the car cool down, topped up the coolant and took it for a drive only to find that the heating was now tepid at very best - not freezing cold but certainly not warm.
Does it sound like I still have a fairly significant air lock and that’s why I’m not getting heat?
Couple of questions -
There’s a fault code for the auxiliary water pump on the FBH - a permanent electrical failure. Is this needed to generate heat into the cabin when the car is running? My thoughts are not but I can’t find anything conclusive.
The car had a replacement oil cooler 8000 miles ago before my ownership and the invoice shows “full coolant flush” - is this likely to be the source of the major air lock / heating issue and potentially been prevalent since?
Finally, I noticed earlier that when having the AC turned on but the heating set to high, it’s absolutely stone cold, it genuinely feels like the AC is set to low. The only way I can get anything like warm at the moment is to have the Ac Button off - can anyone provide any logic to this?
Post #725010 23rd Sep 2025 9:28pm
NorthernChap
Just to add to this - the changeover valve that I bought isn’t a genuine LR item - it’s aftermarket but is the exact same unit that I used on my previous 405
Which worked perfectly. I guess there’s a small chance of this one being faulty? I tested the solenoid function before fitting and the engaged the solenoid as expected when receiving 12v
Post #725011 23rd Sep 2025 9:34pm
fisha
Did you unbolt and lift the reservoir tank up to bleed the system … it needs to sit about 10-15cm higher than its normal position for a proper bleed, not just parking it nose in the air. V8 or else ...
Post #725018 24th Sep 2025 7:24am
NorthernChap
I didn’t, I have just been doing it in situ. I’ll give that a go at some stage today
Post #725019 24th Sep 2025 7:37am
fisha
The workshop manual (link in the wiki of this site ) has a description of how to do it. I think basically the tank needs to be raised in order to get it above the height of the rear aircon unit in the boot space . V8 or else ...
Post #725020 24th Sep 2025 9:07am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I found that when my changeover valve failed that one of the two pipes that run upto the EGR unit from the left hand side of the block (looking at the engine) was cold and the other hot. Maybe worth getting it up to temperature and popping the engine cover off and just checking both pipes are hot to discount the valve from the problem.
I'd already taken my valve off and tested it and the solenoid worked perfectly, re-assembled and still no heat. Popped a new genuine item on and heat restored, on stripping the old valve down I think the o rings swell and cause a flow restriction.
There is a specific bleed procedure for vehicles with 3 or 4 zone A/C (you have the extra A/C unit in the nearside rear 1/4) that involves diconnecting the coolant lines under the n/s/r wheel arch and purging air from this point, pretty sure it's in the wsm.
Edit: the aux FBH coolant pump is only used to pump the coolant when the FBH is running and the engine is off, once the FBH cuts out the pump stops - at least it does on mine! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #725022 24th Sep 2025 9:17am
