Home > Maintenance & Mods (L322) > Rear bags
Rudyard1
Rear bags
Has anybody ever replaced their rear bags? Just interested to see who has and which company you used……
Same really for rear shocks - what make and did you notice a difference in ride? Mine are still original(!) 2007…… 2007 Range Rover Vogue 3.6 TDV8
Post #725051 24th Sep 2025 9:11pm
JayGee
Any problems with leaks or signs of the airbag rubber deteriorating around the main fold area?
Does the rear end feel bouncy when you push it down and release it or does the cars handling feel unstable when cornering?
If it's not broken - don't fix it. 2012 TDV8 Vogue (L322)
Post #725059 25th Sep 2025 7:00am
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Think mine are original 2005......leave until i hear hissing Laughing
Post #725096 25th Sep 2025 4:36pm
JayGee
When I replaced the fronts which had 'perished'
I also bought a pair of rear bags as I though they would be in the same condition but upon inspection they were absolutley fine so left them alone. 2012 TDV8 Vogue (L322)
Post #725104 25th Sep 2025 6:05pm
Rudyard1
Thanks for the replies - I may just leave them alone and change the dampers. Bags are original and look to be pretty stout! 2007 Range Rover Vogue 3.6 TDV8
Post #725110 25th Sep 2025 7:50pm
IMissNimoy
United States 2011 Range Rover HSE 5.0 V8 Zermatt Silver
All the air suspension in my 2011 is original to the car. I just examined front and rear suspension this week. Front looked similar to the pic in the above post, albeit not quite as bad. The rear bags have no cracks, but both dampers have leaks. So, same as you, I'll just do dampers. 2011 L322 HSE Lux 5.0 NA
Post #725112 25th Sep 2025 7:59pm
JayGee
Minor fluid seeping from CVD rear shocks is normal and not a sign of failure or a need for replacement. 2012 TDV8 Vogue (L322)
Post #725114 25th Sep 2025 9:18pm
dhallworth
I replaced them on my old 2007 L322 with Bilstein. I never had any problems with them but I've seen others saying that the bags are too short and tend to cause trouble if you put the car into off-road height.
I can see the logic in not replacing them if they're not leaking, however, if they burst and leave you stranded they could be a nightmare.
Personally, I'd have a good look at them and make sure the rubber isn't showing any signs of perishing. On both of our 2012 cars the bags look to be in great condition.
Post #725116 25th Sep 2025 9:55pm
JayGee
AFAIK it’s only the later cars with CVD shock absorbers which cause a problem with some air bags. 2012 TDV8 Vogue (L322)
Post #725123 26th Sep 2025 6:52am
GraemeS
Australia
Longer shocks were fitted to MY07-MY09 TDV8 but they weren't CVDs. L405 D350 SE Carpathian Grey D5 19" rims
Post #725129 26th Sep 2025 8:16am
Rudyard1
I’m acutely aware that as I am now in possession of a early type rear sub frame for 2007 RR that am I going to have to replace the rear arms, suspension, toe links, ride height sensors etc to retrofit?! 2007 Range Rover Vogue 3.6 TDV8
Post #725246 27th Sep 2025 9:19pm
IMissNimoy
Not trying to hijack the thread but since OP mentioned dampers and @JayGee said minor fluid was normal..... Mine are original 2011 and look like this.
Post #725275 28th Sep 2025 3:01pm
