Home > Maintenance & Mods (L405) > Cleaning steering buttons success
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
I decided to try 99% rubbing alcohol of the steering wheel buttons as they were really gummed up and looks terrible, also they were really sticky to touch. Just used some rubbbing alcohol and very happy with the outcome. Here are some before and after photos, took about ten minutes rubbing but worth it.
Post #725635 5th Oct 2025 9:49am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
had to do the same thing works a treat that stuff L405 2014 Loire blue Autobiography
Post #725660 5th Oct 2025 6:22pm
fisha
Mine are going the same way. Need to try that. V8 or else ...
Post #725665 5th Oct 2025 7:27pm
tj196443
I nearly bought a used pair for £65 but glad I didn’t , they take a bit of elbow grease but can be done in about ten minutes and the results are worth it. I’m going to seal them with some interior cleaner so they don’t get gummed up again.
Post #725667 5th Oct 2025 8:11pm
garyRR
I fitted the newer style buttons. Easier to keep clean and the cheap nasty clicky buttons really let the car down.
 2015 Range Rover Autobiography 4.4 SDV8
Post #725962 10th Oct 2025 1:31am
tj196443
That looks very neat Gary and more modern than the originals fitted to the earlier cars. I was tempted to go down that route too but cleaning was easier than swapping out, I may still buy a set in the future though. Did you find them easy to install ?
Post #725967 10th Oct 2025 7:45am
garyRR
Yes? Easy enough. They took about 30 minutes to do. 2015 Range Rover Autobiography 4.4 SDV8
Post #725968 10th Oct 2025 7:59am
