Home > Technical (L322) > Transmission Fault, Now we have Codes
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Ok initially reported the transmission fault message appearing in the instrument display, but no codes in the TCM, link to post here;
https://www.fullfatrr.com/forum/topic74586.html
So have had the transmission fault message appear a couple more times, under load (pulling a horse box) or heavy acceleration. Gearbox seems to go into failsafe mode until engine switched on and off again.
We now have codes;
ECM U402 Invalid data received from transmission control module
TCM P0741 Torque converter clutch solenoid- circuit performance or stuck off
I am being advised I need a full rebuild. I would welcome any comments on potential courses of action before this step. The transmission has had a recent filter and oil change with genuine ZF. Old oil did not look too bad. All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #725826 8th Oct 2025 10:33am
RRPhil
Clearly the communication/interface U-code will be tricky to pin down, but I guess you could start by replacing the torque converter lock-up clutch solenoid to see if this addresses the P-code. The torque converter LUC may have a mechanical or hydraulic issue which prevents it engaging, which would necessitate its replacement/remanufacture, but the EDS6 solenoid can be swapped out with the transmission in-situ so would be a relatively straight-forward thing to try initially.
The part number of the yellow-capped solenoid is 0501 213 960. It could be an expensive way to find out that it wasn’t the solenoid at fault if you purchased a new one. I have several used ones lying around, if you wanted me to send you one to try?
Phil
Post #725867 8th Oct 2025 7:39pm
