![]() | Home > In Car Electronics (L405) > L405 No Radio Power/Sound |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1437 ![]() ![]() |
I had this when my Amp froze but the screen was lit. Its actually happened twice in the last 4 years I suspect it happens when the battery charge gets low so I usually use the cetek charger every 2-3 months to avoid the "Start Engine now message"
djrj05 Member Since: 15 Oct 2025 Location: Arkansas Posts: 2 ![]() ![]() |
Thanks for the tip, however neither the upper or lower match that junction diagram. Is there another location?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35867 ![]() ![]() |
I would start at a battery disconnection...check the battery condition as well.. ... - .- -.
That was for a my18 L405 its in the "trunk" for us brits its on the drivers side behind rear trim panel. Check the Work shop manual for a 2014 maybe its somewhere else for yours? 2018 SE SDV8 4.4 Byron Blue |
