![]() | Home > Technical (L322) > Rear Suspension 2012 TDV8 |
| Pug Member Since: 19 Oct 2025 Location: Oxford Posts: 17
Not sure if yours will be the same as mine but this is what I found with my 2006 L322 which wouldn't calibrate. Spent about 20 hours on and off trying to sort this out.
Its also possible all your sensors work the same way in which case your bracket may just need a tweak to get it reading the same. Can test the bracket theory by unclipping the sensor from the suspension arm and move it full range to see what voltages you get. If the voltages are right then reconnect it and just bend it. |
| Jason66 Member Since: 02 Mar 2023 Location: Guildford Posts: 18
I think it was on its bump stops when I took the reading. I’ll take a look at the bracket and maybe unclip. Thanks for this. 2012 Westminster Aintree/Ivory 4.4TDV8 |
| Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 308
This will help: https://youtu.be/9ot3L4CHPd4?si=jG2qrqGXISW6aeMZ&t=20m FWIW : I would also suggest a Hunter 4x4 wheel alignment. After I had mine done at GlenRands it was like driving a different vehicle. TDV8 4.4 2012 Last edited by Ramblin Man on 20th Oct 2025 5:10pm. Edited 1 time in total |
Nothing to lose, I prefer free fixes over costly ones 😂 |
That’s a great shout on alignment, thank you. Will watch the video. 2012 Westminster Aintree/Ivory 4.4TDV8 |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032
and remember to use the GAP IID tool to put the car into "Tight Tolerance" mode before you do the wheel alignment |
| RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 92
How much would Glenrands charge for that? I had my tyres done at a local place but I am not that happy with the alignment they did (they had two goes at it and the wheel is still cocked with a vibration coming through). I am quite far from Glenrands or I would have taken it there, but I might be going past in the new year. |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3402
Glenrands are a lot more expensive than a standard tyre fitter for a Hunter 4 wheel alignment but they will persevere until it’s right which is worth it. I paid around £270 a couple of years back. No point having it done IME unless all your suspension joints and bushings are tested and free of movement or wear. 2012 TDV8 Vogue (L322) |
Cheers JG, I did my rear suspension bushes earlier in the year, not done the fronts yet, maybe if I replace those I will go for the hunter alignment. |
Gotts in Alton did my Grenadier. Digital machine so had a print out of before and after. Adjusted the suspension caster as well. Was the right side of £200. Glenrands are fairly local to me and I need a few other bits doing so will be making my way there at some point. 2012 Westminster Aintree/Ivory 4.4TDV8 |
| All times are GMT |
