Home > Technical (L405) > L405 Door handle lock switches not functioning
MGSED37
United Kingdom 2014 Range Rover Vogue SE SDV8 Aruba
Hi all,
Getting on ok with the L405 since we've had it earlier in the year. Still a few little niggles.
Today's niggle being the N/S front door handle has stopped locking the car.
It did this previously but the garage fixed it and now its gone again.
Its when you touch the touch button on the front it doesn't seem to work.
Any ideas what to look for or any common things to try before I go at it.
Any help would be greatly appreciated.
Many thanks
Post #726746 23rd Oct 2025 8:00pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Depends which type of handle you have, either the fully moulded type or the one with the inlay trim, if the latter there was a tsb for the locking button failing, basically the wires under the trim can corrode and fail causing the lock function to cease working. You can carefully take the handle apart to access the wires and make a repair. If you have a GAP IID you can monitor the handle and it will show if the proximity sensor is working or not.
If you don't have a GAP tool, you can swap the handles around from another door (they are all the same) to see if the affected door then locks with a different handle, this will then isolate the problem to the handle. Handle is easily removed, just one torx screw and one electrical connector.
If you try and source a secondhand handle, just be sure to check the amount of pins in the electrical connector as they can had 4 or 6 depending on the vehicle spec.
Here's the TSB:-
https://static.nhtsa.gov/odi/tsbs/2018/MC-10142745-9999.pdf L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #726759 24th Oct 2025 8:08am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Three of mine did that. New door lock actuators fixed them. Two replaced under warranty, one I did myself. I got a used one from eBay and replaced it in under two hours going slow. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #726787 24th Oct 2025 2:15pm
MGSED37
Many thanks for your replies. I'll certainly look into the gap tool, think its worth getting. Have to be honest, not sure which handle is which, so I've added a picture. Could someone tell me the type if possible so I can tie it up with the relevant fix?
Thank you again for your help. I'll have a look at getting the handle off, the issue does seem to be intermittent
Post #726832 25th Oct 2025 3:09pm
4RRS
That's the type that I've described above as being problematic. It's referred to as no.3 in the document. I'd just use some heat and a plastic trim tool to remove the inlay trim. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #726837 25th Oct 2025 4:00pm
MGSED37
Thank you, very much appreciated. I've just ordered two spare handles to have a practice on. May have some more questions when I've opened them up. Are these coded at all or just plug and play ? Thanks again.
Post #726879 26th Oct 2025 6:56am
4RRS
Straight swap, no coding required. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #726883 26th Oct 2025 7:26am
MGSED37
Awesome stuff thank you, will reply back with progress.
Post #726896 26th Oct 2025 9:42am
Can you get these off without removing the inner door card, the manual seems to suggest you do have to remove it... Cheers.. Thumbs Up Pete
-Click here for Thread-
Post #726897 26th Oct 2025 10:19am
4RRS
Just pop out the plastic bung as per picture, undo the torx screw a couple of turns (don't screw it all the way out) and then the handle is loose, slide towards door edge and then lift out.
Post #726901 26th Oct 2025 10:39am
Cheers mate, easy when you know how...lol... Bow down Pete
Post #726908 26th Oct 2025 12:38pm
