![]() | Home > Technical (L322) > Passenger door locked up |
| steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 64
YES it is. At least in my case. I have a 2003 TD6 and 2004 4.4 petrol. Both cars exhibited the same problem when I purchased them. You do not state what you car is so what I did may not apply if your car is later Ford electronics.
| MonsterBabyBLN Member Since: 06 Aug 2025 Location: Berlin Posts: 10
Awesome. That's probably some great help.
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836
try replacing the BCU, worked for me RR 2005 4.4 petrol
I'm at it again as the door decided to unlock one more time.
| Pug Member Since: 19 Oct 2025 Location: Oxford Posts: 16
Sounds like the door module or lock mechanism is stuck in "superlock" or deadlock.
Thank you. Everything else works. So no super locking.
Hope it is that.
Ok. But as I understand with superlock engaged the window wouldn't work either? |
Not quite.
Thank you guys for the support-
Lever from outside? The door handle?
no idea what year yours is, mine is 2005
