![]() | Home > In Car Electronics (L322) > Retrofit Dual View Screen |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
Morning,
I think the systems are fundamentally different. Although I could be wrong, I thought there was a significant change in 2007/8? And then again in 2010?
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
they both use can bus but i think 2010 and on is 128 system bit as the 2006 is 64 bit, well its along them lines V8 facelift Range Rover Autobiography 22" wheels.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
i read the same somewhere dave.. ... - .- -.
Good info. Thanks chaps.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
I thought the FFRR after 2006MY infotainment system used a MOST network rather than a can bus, prior to 2006 it was ibus. |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
2005MY had the infotainment upgrade to the MOST network and will support the Hybrid TV tuner from a 2010MY. It is a slightly smaller box that will only fix in place with 2 screws rather than 4. One connector port is not used but it doesn't impair the use at all. You get free view and analogue channels and a now and next programme info bar on screen when the channel is changed or the current programme ends.
Erm, not entirely sure that even a full replacement of the whole system would work. IIRC up to 2010 the CAN bus uses 29 Bit extended addressing, but after 2010 it moved to 11 bit standard addressing. Unless someone like Colin from Blackbox knows of a magic voodoo box to make the translation then post 2010 infotainment won't work in a pre 2010 car. |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
You are correct they have changed the CAN bus system from a 29bit system (pre 2010) to an 11 bit system (post 2010) the two CANNOT communicate with each other without some sort of translation. |
