![]() | Home > Technical (L322) > td6 air con condenser |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
has anyone fitted or knows how to fit one of these.. ... - .- -.
the system is empty, hence the condenser replacement..appreciate the advice.. ... - .- -.
Cant see it being to hard a job. If it's the one to sit infront of the rad you might have to remove it to gain access but shouldn't be to hard. Have you looked in Rave to see what's involved? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
it is in front of the radiator rob,that's why its got holes in it .probably damaged from stones and debris from the road.. ... i havnt browsed rave yet but will do.. |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
When I replaced mine, I removed the slam panel and front grill. Saves undoing the viscous fan unit.
not sure what the slam panel is rich |
Above your headlights, below your open bonnet, the bonnet "slams" on it |
thanks |
Not to bad, an hour (ish) Some fittings to remove, i.e. bonnet cable and air duct.
much appreciated rich... ... - .- -.
2nd Rich's advice.
thanks steve, condenser ordered @ £168 delivered with 18 month warranty... ... - .- -.
That seems quite reasonable.
$115 converted to uk would be even cheaper...dont think the wife would allow me to get a flight to the states to collect one... |
