![]() | Home > General > Check Coolant Level :-( |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Whilst driving to the dentist, the chap behind flashed, pulled along side and warned me that my car was dropping a considerable amount of water, just as he finished telling me, my car bonged to warn me to check the coolant level.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
anything obvious justin? ... - .- -.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Hopefully nothing to much to fix. Reformed |
Ah you supercharged loadsa munny owners can afford it |
I can't see anything obvious. ![]() Gone - Range Rover Supercharged 2006 ![]() |
Dom - My kids can only afford to eat every other day because I bought a FFRR SC ![]() Gone - Range Rover Supercharged 2006 ![]() |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Mine did the same after a 400 mile drive to Aylesbury, pulled up outside the hotel when I got the warning, mine was a small split in the header tank to radiator hose, not a very big job, lets hope yours is just as minor. 2006 Mercedes CLS
The LR assist chap located the offending coolant pipe, and as the split was close to the edge he chopped about 20 mm off the end and reattached with a new jubilee clip. So I'm mobile again |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
glad it was nothing serious |
magic mate.. |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
good.... |
Looking at microcat it look like the pipe runs from the font of the engine to the back, it's the narrower 25mm pipe not the fat stumpy one that connects to the engine block.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Not going too far off topic but I've had to top mine up a couple of times recently, nothing drastic (the low coolant light hasn't come on) I noticed that when cold, it had dropped from the upper level to midway between upper and lower.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
If it's being topped up by exactly the same amount it could just be finding its level |
