Home > Technical (L322) > how to remove dashtop ?
BrianC
hi i am going to remove the dashtop to check the connections for my reversing camera, is there anything else to take off apart from the screws at the top ?
Post #83714 25th Sep 2011 11:59am
ric355
The ends have to come off as well.
(dash top - mentions ends have to come off)
The other vid showing ends is in his list somewhere.
Post #83715 25th Sep 2011 12:02pm
BrianC
thanks for the link , i think ill leave it alone for today.I am thinking the camera is plugged into the wrong input because when i do the test it is showing to be working.
Post #83716 25th Sep 2011 12:05pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i removed my dash last month to fit a VIM module. one thing i would say is be very carful when you are undoing the clips that secure the side air vents. the louvres are only held in place with a very small plastic stem and i snapped one of mine when i slipped with my screwdriver... Sad
i have since sorted it out but just to make you aware, i think everything else is fairly robust. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #83728 25th Sep 2011 3:02pm
Just a little tip, before you take the dash end covers off (wood or foundry parts) use a small flathead screwdriver and take tha airbag badges out of the A pillars and remove the torx screw. Then the A pillar covers just pull off. This will save you marking them when you put the end panels back on after refitting the dash top...
Trust me you'll be glad you took the extra five mins...
Regards Craig Thumbs Up
Post #83732 25th Sep 2011 3:13pm
BrianC
thanks for the tip Thumbs Up
has anyone looked at the back of the touchscreen to see if the inputs can be swapped ?
Post #83757 25th Sep 2011 6:16pm
