![]() | Home > General > Suspension Query Part 2 |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
One of the many joys of owning a FFRR ![]() |
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
is the suspension f*****d? of just one of these technical gremlins?
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Mine has done it before as well.......... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
If you stopped and restarted with no faults it looks like it could have been a glitch. Best just keep an eye on it and hope for the best, or as an ex manager of mine used to say....."Let it develop" |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Possible the compressor wasn't able to keep up with demand.
Every time i stop the vehicle i always put the car into access mode as i like the suspension to keep flexing is this the correct method to keep the suspension active? |
Some believe so, I personally don't bother |
Well I can hear the compressor when it runs due to the LPG relocation (not too loud, but audible) When you are aware how long it runs for and how hard the thing works you wouldn't put it into access mode every time you stop it !! I leave mine in normal mode - occassionally I drop it and raise it but certainly not every time..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
True but then the other argument is leaving the vehicle in normal mode puts unwanted stress on the vehicle having to continually monitor the pressure while left parked overnight say? |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
This is moot - if there are no leaks then nothing will happen. There is no "stress" in monitoring the height of the vehicle when it isn't changing. Conversely if it does change height then you have a leak and therefore already have something that needs fixing! I don't get the stress issue anyway - there's still air in the bags whether it is in access mode or normal mode. Just less of it in access mode but it's still holding up the weight of the body; it is not resting on the bump stops. Obviously the more times you lower and raise the more wear there will be on the compressor. But using it isn't a bad thing - that's what it's for after all. Just park it up and don't worry about it. The only reason to always put it in access mode would be if the owners handbook tells you. And I doubt it does. |
Why oh why did I read this thread earlier today.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
joe, if you have time ,put "air suspension inactive" with the quotation marks into the search and there is tons of info re this...i had a quick read but didn't get a definitive answer, mind you a only read a few threads.. ... - .- -.
Try disconnecting the battery for half an hour, though if it does re-set it will most likely pop up a fault as soon as you drive again.
@ scarey - that's what I've just been doing since I posted, just thought I would report the synchronicity of reading about the ASI problem and it then happening to me |
