Home > Technical (L322) > Do I need to replace all 4 brake sensors?
Dolphinboy
Just to be safe, am just about to replace both front and rear discs and pads, having had the red warning light come on for a brake sensor alert.
Question is: Is this just one brake sensor activated or do all have to be replaced when replacing the discs/pads etc.??
Post #88638 23rd Oct 2011 8:52pm
only two sensors james and only replace the one which is worn.. ... - .- -.
Post #88639 23rd Oct 2011 8:54pm
Dolphinboy
splendid. Many thanks. night night Stan Thumbs Up (you do sleep at some time don't you?? Whistle )
Post #88640 23rd Oct 2011 8:56pm
cheeky bar steward... Laughing ... - .- -.
Post #88641 23rd Oct 2011 8:58pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
I replaced my disks and pads 2 months ago.
My first surprise was that I only have one sensor for front pads, and on for rear pads. I only have the front one dead, I can re-use the rear one as the contacts were not used.
I don't know it is normal to have only 2 sensors, but I didn't see wires on the opposites sides...
Post #88642 23rd Oct 2011 8:59pm
only two sensors raf, one on the front near side [afaik] and one on the off side rear.. ... - .- -.
Post #88643 23rd Oct 2011 9:09pm
Fr_Raf
Thank you Scarey, nothing different here. One in the front left, and the other on the rear right Bow down
Post #88656 23rd Oct 2011 10:09pm
Be carefull removing them as most will shatter as the plastic gets brittle with age and heat,,,
Craig Thumbs Up
Post #88663 23rd Oct 2011 11:43pm
Andy
The vehicle only needs one sensor - reason being the pads are supposed to wear at the same rate in normal conditions 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #90975 8th Nov 2011 11:41am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Yes, works well that system, except when they don't wear at the same rate, which is what caused a three hour ride in a big yellow taxi on my way back from Scotland! Censored 2012 SDV8 Vogue SE
Post #90986 8th Nov 2011 11:59am
