Home > Technical (L322) > [SOLVED!] Tight Bastard! Recommendations on Seized Bolt? |
In the process of changing a front air spring.
29th Oct 2011 7:37pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
If the socket, or spanner is a good tight fit, you could use a bottle jack or trolley jack to to put extra pressure on it. Or if you have an extending wheel nut wrench they are great for extra force on nuts/bolts. Previously..
29th Oct 2011 7:44pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1240 |
I have 2 breaker bars for things like that.
29th Oct 2011 7:45pm |
See what was needed just to undo the nuts (they have come off OK, it's just the lower bolt that is being stubborn)
29th Oct 2011 7:58pm |
If the nut is off the lower bolt should push through, it isn't threaded.
29th Oct 2011 8:07pm |
If you have a good fitting socket, 6 point not 12 point you can use a breaker bar/ tube and prop the end off the ground with a brick or lump of wood and gently lower the car jack. Gravity is a wonderful thing when backed up by a b y great weight. |
29th Oct 2011 8:29pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I have a five foot long, 750lb torque wrench for such occasions, plus plenty of BFI (Brute Force and Ignorance!!) |
29th Oct 2011 9:06pm |
We have a five foot bar for those bolts! If you have it moving slightly then just keep moving it a little at a time (spraying it with WD40) and trust me it will get easier and easier. We have taken 2 hours to work those bolts out sometimes!
29th Oct 2011 9:57pm |
Leave nut on end of bolt if you're going to bash f k out of it, so it doesn't "mushroom" the end, simples... |
29th Oct 2011 10:06pm |
Thanks to all for advice and encouragement, with the first few attempts failing, had to walk away and think about it, so more of the same tomorrow. I will persevere with working the bolt round rather than beating the s t out of it .
29th Oct 2011 11:45pm |
Success!
30th Oct 2011 7:11pm |
Glad you got it sorted.
30th Oct 2011 8:09pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
As my dad always said "you know you have done a good job when blood has been shed!" [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Oct 2011 10:35pm |
