![]() | Home > General > Lpg V8 at last |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
The fan always comes on for a minute or so when you open a door or the boot or the bonnet |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35767 ![]() ![]() |
fbh should be located near the near side wheel arch..if its on your touch screen switch it on and see where the sound is coming from.. ... - .- -.
SparkyPhil Member Since: 29 Oct 2011 Location: Staffs Posts: 59 ![]() ![]() ![]() |
Thanks for the replies, I have tried switching it on but when I press the on button it just goes straight off again, the heater/fan does not even come on. |
i think you'll find that the outside temperature must be below 5 degrees? to have it work.. ... - .- -.
Thanks for the info 47p2 & Scarey much appreciated |
K20FTY Member Since: 15 Nov 2011 Location: Derby Posts: 13 ![]() ![]() ![]() |
I'm sure i've read somewhere that the fan you hear is an internal one to draw ambient air over the internal (cabin) temperature sensor, so that when you start up, you get a realistic response from the heater/air-con, as it's 'pre-measured' the current cabin temp. 2003 L322 Vogue SE 4.4 + LPG
sounds reasonable.. ... - .- -.
