Home > Technical (L322) > Check engine light - again..... |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
what was the error last time... V8 facelift Range Rover Autobiography 22" wheels.
6th Nov 2011 7:18pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
What was the fault code last time? Mine seems to come on sometimes with code 430, something about catalytic converter efficiency. I reset it with the IID and drive on happily. Never an issue, just slightly annoying. Great to have the IID and be able to reset it so quickly! Range Rover-less at the moment - Pining! |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
My SC displayed a transmission fault - limited gears error message followed by the EML lit when I turned the ignition on today, I cycled the ignition switch and the message has gone but the EML remains lit. The car drives fine, so I'm going to leave it for a few days to see if it clears itself.
6th Nov 2011 7:20pm |
EML dont sound like the result of a transmission fault, this would come on due something with the engine, not sure i have read that the batt probs would bring on the eml but some one on here may of had it, but my guess would be that its a fault on the engine system, check the fault again and ask for the error code.. V8 facelift Range Rover Autobiography 22" wheels.
6th Nov 2011 8:04pm |
just noticed we have two members with the same prob.. V8 facelift Range Rover Autobiography 22" wheels.
6th Nov 2011 8:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
would an eml fault be due to an injector fail.. ... - .- -.
6th Nov 2011 8:10pm |
My battery was replaced less than 12 months ago, whilst it could be faulty I think it's unlikely to be the cause in my case.
6th Nov 2011 8:11pm |
true, i think the fault is with the engine, yes could be an injector,coil or sensor but i think the best and only way is to have the fault read, V8 facelift Range Rover Autobiography 22" wheels.
6th Nov 2011 8:16pm |
A common cause of the eml coming on on petrol engined cars is a fault with an oxygen sensor. The V8 has 4
6th Nov 2011 8:20pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Almost all EML lights are due to emissions, and as stated most are O2sensor problems. My last one was a bank running lean. A quick reset and LPG retune and 8months later still hasn't returned. When I have checked recently had an O2 sensor wide open error so guess I have one on the au out. Think they are about £50 each so not massively expensive. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
6th Nov 2011 8:45pm |
LostInSpace Member Since: 28 Apr 2011 Location: Pulborough, West Sussex - ex NZ Posts: 107 |
@ bozman - Fault last time was running lean on bank 1-4, but I didn't get the actual code.
6th Nov 2011 10:17pm |
IID = http://www.fullfatrr.com/forum/topic7073.html ... - .- -.
6th Nov 2011 11:08pm |
Running lean could also be an air leak on the induction side. The engine getting extra unmetered air up the air to fuel ratio. Quite common on te 4.4 due to perished breather pipes but not sure about the supercharged jag engine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
7th Nov 2011 8:53am |
