Home > Maintenance & Mods (L322) > Rear washer.
Johnte
Rear washer.
Isn't working - where's the jet, I must be missing the obvious as I can't see it anywhere Confused
Post #91410 10th Nov 2011 1:26pm
On mine, when I first use is after a while it takes AGES for the water to come through and when it does, it seems to run down the wiper blade (from the top), so I assume the pipe's attached to the end of the wiper blade itself? Got - 2017 SDV8 Autobiography in Loire Blue
Post #91412 10th Nov 2011 1:32pm
It's at the top of the wiper under the brake light , think you will have to make sure the wiper is half way through its cycle and switch the engine off so that the blade wiper arm at sitting exactly in the middle of the screen … ====================================
Post #91441 10th Nov 2011 3:45pm
wiki? ... - .- -.
Post #91443 10th Nov 2011 3:52pm
it's not Wiki… it's just not Worki …. Laughing Laughing ====================================
Post #91444 10th Nov 2011 3:54pm
woki u say? Very Happy ... - .- -.
Post #91449 10th Nov 2011 4:14pm
The jet is on the arm spindle end.
It does NOT adjust so don't stick a pin and try to move the direction like you would with the front ones.
It's a rubbish design and they seem to fail quite commonly.
You may end up needing to read this:
http://www.fullfatrr.com/forum/topic884.html Discovery 4 HSE
1998 90 TUL FFR Hard Top XD Wolf
1993 90 Tdi
*Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB
Post #91451 10th Nov 2011 4:17pm
Googsy
Mines like yours Alan it just runs down the rear screen is that how they are supposed to operate or should I be expect more of a squirt like the fronts ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #91489 10th Nov 2011 7:32pm
Expect a squirt , something near as the fronts ... ====================================
Post #91490 10th Nov 2011 7:34pm
Vogue
mine just gushes down the screen, and has done so since new - never squirted!
Post #91513 10th Nov 2011 9:18pm
I have just recently replaced the non-return valve on the rear washer. It is like new now with a healthy squirt. It was taking forever for the water to come out as it was all running back down the tubes! £2.50 from halfords, and the stealer was wanting £80+ just to investigate.. Previously..
Post #91516 10th Nov 2011 9:32pm
That about sums mine up! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #91518 10th Nov 2011 10:07pm
comports
Hey Contraband - Would be good to get a description of what you did for others suffering the same common problem.
Could you do a quick para on what you did, what you bought and where/how you fitted it.?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #91554 11th Nov 2011 9:16am
T24RES
I'm going to be interested in a new one way valve Thumbs Up Every time i use the washer its dry the first time, then slight success, then it gushes all unnecessary Mr. Green
Post #91555 11th Nov 2011 9:20am
Sounds like its a female washer jet arrangement! Rolling with laughter Rolling with laughter Rolling with laughter
Craig Thumbs Up
Post #91557 11th Nov 2011 9:33am
