Home > Off Topic > wiring for induction hob
my the kitchen project is progressing and i will soon need to wire up an induction hob..is there anybody in the 'know' that can advise me whether i can splice into my cooker [30amp ?] cable.. ... - .- -.
Post #92139 14th Nov 2011 5:07pm
Bodsy
don't know if you 'can' or not, but most cooker switches are 30amp and that should be fine for the oven and hob. We have an induction ceramic hob thingy currently and both that and the oven is on a 30amp direct cable (via a fused cooker switch) back to the main consumer unit. Thumbs Up
Post #92142 14th Nov 2011 5:19pm
so thats both on one cable yes?
how do you find the induction hob , i'm still trying to convince the wife that its the way to go especially as she wants the hob on an island/breakfast bar.. ... - .- -.
Post #92144 14th Nov 2011 5:25pm
Bodsy
They both have their own cable, which then both go to one switch with one cable back to the consumer unit. Thumbs Up
As a hob, it's fine, although I do miss using a wok for some quick stir fry action.
It's quite an old one and we're looking at moving back to Gas (We didn't have gas in the house when I first moved in). Main reason to move back to gas is as above Laughing
BUT on the positive side, the induction hob is very flat, so gives the kitchen a much smoother line. For a central island hob, is ideal i would say. Thumbs Up
Post #92145 14th Nov 2011 5:34pm
thanks for the info and advice bodsy.. Thumbs Up ... - .- -.
Post #92146 14th Nov 2011 5:40pm
Check the ratings on your cooker and hob before doing this. If together they exceed 30 amps then its a no no.
Would make more sense to run a separate supply but that is probably not possible, but perhaps at least run a spur from the cooker connection on the wall so you have a separate connection point / and switch?
By law this needs to be checked by a qualified electrician. Competent person is probably not good enough (even though we all do it!) Wink .
Post #92245 14th Nov 2011 10:52pm
thanks joe..i'll be running a spur from the 'oven' switch and both the oven and hob comes to 27 amps so its within the 30 amp rating ... ... - .- -.
Post #92247 14th Nov 2011 10:56pm
Have you ever seen the flash from a 27 amp blow not forgetting the bang, it makes a heck of a mess Whistle
Post #92250 14th Nov 2011 11:00pm
no, but i've drilled into a live mains cable... Mr. Green ... - .- -.
Post #92253 14th Nov 2011 11:03pm
BBBBZZZZzzzzzzzzz, FLASH!!! Rolling with laughter Got - 2017 SDV8 Autobiography in Loire Blue
Post #92254 14th Nov 2011 11:05pm
Well that was a silly thing to do Rolling with laughter Rolling with laughter
Post #92255 14th Nov 2011 11:11pm
