Home > General > Self-Levelling Suspension
Phil.
Am thinking about upgrading next year and think I want self-levelling suspension. A few questions:
- When was it introduced?
- Is it an option or standard?
- What is the effect (if any) on tyre wear? I assume the forces have to go somewhere?
- How much difference to the ride does it make?
Post #93246 18th Nov 2011 10:03pm
have not all the ranges have self levelling suspension?
Post #93260 18th Nov 2011 11:23pm
Yep Whistle 2008 MY Supercharged
Post #93262 18th Nov 2011 11:26pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
1993
Hth
David
Post #93266 19th Nov 2011 12:30am
Phil.
Thanks guys Wink
I thought around 2010/11 it was improved so that cornering was flattend?
Post #93273 19th Nov 2011 8:45am
maybe but i'm pretty sure the s/c has a stiffer setup ...
Post #93274 19th Nov 2011 8:51am
johnson1
10MY saw the introduction of Adaptive Dynamics which stiffened up the body shell and reduces roll on bends ALOT. Self levelling has been standard throughout the L322 and, as others have said, much much earlier in terms of Range Rover.
Post #93275 19th Nov 2011 9:18am
Phil.
Thanks Johnson - my incorrect use of terminology.
So the above questions still apply to Active Dynamics rather than self-levelling Smile
Anyone with experience of Active Dynamics on the FFRR?
Post #93276 19th Nov 2011 9:20am
ebajema
The S/C already has a pretty stiff suspension and corners quite flat. But I also know that the LR engineers do a lot of tweeking and tuning on their cars so the newer versions will be better. The question is by how much of a margin. A FFRR will never be cornering like a Ferrari/Aston/Lambo etc. although it is quite impressive what they have done on the S/C.
I thought it looked pretty impressive when the L405 was thrown around the Nurburgring on the video clips we saw in one of the other threads Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #93278 19th Nov 2011 9:21am
johnson1
It's a very good system and I can, and do, corner quickly. You can feel a slight roll but it doesn't throw you out your seat! As others have said, it's never going to work like a BMW round corners. There are so many more benefits to 10MY+ so if you can stretch to one, do.
Post #93281 19th Nov 2011 9:55am
Phil.
Thanks Johnson
I have had a couple of FF's, the 4.2 S/C and the 3.6 TDV8. Both have worn the front tyres more at the outside edges due to the cornering forces. Does the Active Dynamic system increase this wear noticably?
It won't make any difference to my decision to upgrade, just interested. And a quick look al LR approved shows loads of 10/60/11 plates with only few miles, all for under £60k Wink So plenty of haggle room with so many about.
Post #93283 19th Nov 2011 10:12am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Adaptive Dynamics has made a massive diff to the car Far to many gone...
Post #93284 19th Nov 2011 10:23am
johnson1
No probs. Should definitely go for a 4.4TDV8!!
Post #93285 19th Nov 2011 10:59am
