![]() | Home > Technical (L322) > 2006 Vogue TDV8 - shakes on idle |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Put it into neutral |
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
Do you have bigger wheels on it from standard ones? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Had exactly the same on my TD6 but the previous owner had put 20" wheels on it. Not recommended by LR for that very reason.
WAZZY786 Member Since: 26 Nov 2011 Location: NEWCASTLE Posts: 26 ![]() ![]() ![]() |
No it's just got the normal alloys on - i'm looking for bigger ones though |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3959 ![]() ![]() ![]() |
So does mine, slight increase in revs and everythings fine - I'm not convinced there is a problem. Neutral , change wheel size none of it works for me - it's just a vibration at sub 1000 revs. Geoff |
If you have standard wheels then maybe check your tyre pressures. They can make a big difference if not inflated correctly. Ash
