![]() | Home > General > Spare Wheel |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Sorry but I would have to say that the standard jack is crap. There have been a number of warnings on another forum about the FF jack. May be O'k on concrete but thats all. Good trolley jack is the way to go. I carry a hydrolic bottle jack in mine.
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
interesting that you mention that, you mean something like this
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35820 ![]() ![]() |
thats what i got , not that make but similar...stored in the right rear cubby hole .. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Is the lift sufficient to get the wheel off the ground? Quite a lot of wheel travel to deal with. Is it good on its own or does it need a block underneath it? 2012 5.0L S/C
Yes RR9701 something like that. Enough room around spare wheel to fit it in. Just hope never to use either.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
IIRC you need to put the car into "off road" setting so that the suspension travel is all but eliminated before the wheel leaves the ground when you start jacking..... Got - 2017 SDV8 Autobiography in Loire Blue
Forcing it into extended mode would be better but i don't think this can be done via internal buttons, just a testbook/faultmate? |
funny enough i had to change a flat [salisbury plain ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3810 ![]() ![]() |
I've changed a full set of wheels using the std jack without issue, I also have 15 ton bottle jacks. Don't know what all the fuss is about with the std jack, it fits the locator under the cill and does the job. Yes a trolly jack would be quicker, but its not something you want to store in your boot, and is difficult to use on uneven ground. |
its not the actual scissor jack its self, its the bar that turns the screw bit which ,in my case has bent ..maybe a more robust handle would make it easier to use.. |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
you and your lad did a great job changing that tyre today Stan, must have been some sort of a record and with Disco3 lads looking on as well |
thanks greg, it was the adrenalin pumping there and the fact we were holding you lot up.... |
I didnt feel like you were holding us up. I just felt bad it had happened to you as I was thinking as I drove up that a puncture would be a nightmare. You came prepared though which is prob why you sorted it so quickly. FFRR TD6 HSE
