Home > Maintenance & Mods (L322) > Damped opening of lower tailgate
Page 3 of 12 <123 4 ... 101112>
sidmini
United Kingdom 2002 Range Rover Vogue 4.4 V8 Atacama Sand
CAM-TECH-CRAIG! need some more information please! this looks like a really good upgrade however there are a few things id like to check before ordering the kit and fitting. can you let me know how you accurately define where to drill the 2 holes into the lower tailgate? also how do you drill the side whole the bumper blocks the angle for the drill entry? special tools needed? thanks
Post #100203 3rd Jan 2012 7:07pm
If you place the bracket on the lower boot and leave an equal gap around the outside, look at the picture on the first page of this thread (it will all become clear when you line it up) then drill the top hole and fit a screw. Then close the boot half way and you can get to the drilling angle easily... Hope this helps...
Craig Thumbs Up
Post #100217 3rd Jan 2012 10:46pm
myvatn
Germany 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Contraband wrote:
I bought the new rubber cover from the main dealer, £1.20. The cheapest FFRR part I have ever bought!
do you have a part number?
I searched the numbers for the damper mountings etc. in RAVE
LR017455 1 LIFT - GAS, RH SIDE ONLY, LOWER TAILGATE
LR017590 1 BRACKET, RH SIDE ONLY, LOWER TAILGATE \
LR020219 1 BRACKET, RH SIDE ONLY, LOWER TAILGATE >>
dont know the difference between this three parts
LR021053 1 BRACKET, RH SIDE ONLY, LOWER TAILGATE /
LR003808 2 SCREW, M6 X 16MM, TORX, BRACKET, HEX HEAD, LOWER TAILGATE
LR017461 1 STRAP - CABLE, RH, LOWER TAILGATE
Post #100219 3rd Jan 2012 10:55pm
sidmini
Dan @ Duckworths - could you please verify the parts required for this mod and perhaps package us up a price please? thanks Smile
Also not sure why there are 3 bracket types as per MYVATN's post. CAM-TECH-CRAIG can you let us know the parts if you have the numbers handy? BTW what drill bit size do you use ?
Post #100229 4th Jan 2012 12:19am
I have no idea what screws/bolts Land Rover use to fix them with... We use our own fixings...
I'm sure Dan will give you part no's
Craig Thumbs Up
Post #100231 4th Jan 2012 12:29am
duckworthparts
Site Sponsor
LR021053 bracket
LR017455 strut
LR017461 strap
£21+VAT for the above lot.
there are few variations in part numbers depending on model years, but as this is being retro fitted i wouldn't worry about it
And if you wanted the screws LR003808 x 2 M6 x 16mm You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #100241 4th Jan 2012 9:14am
myvatn
Thumbs Up Dan Thumbs Up
could you please add the option for the facelifted rubber cover for the push button?
Post #100245 4th Jan 2012 9:34am
this might help re the button cover..
http://www.fullfatrr.com/forum/topic4816.h...ate+rubber ... - .- -.
Post #100247 4th Jan 2012 9:39am
duckworthparts
Site Sponsor
and its a whopping £1.00+VAT from myself Laughing You can paypal direct using - www.paypal.me/duckworthparts
Post #100248 4th Jan 2012 9:48am
sidmini
Cam-Tech-Craig - thanks for the information but still a query in my head. The parts thats Dan refers to are m6 x16mm screws to secure the bracket to the lower tailgate but surely this only applies to the pre-drilled lower tailgates provided by the factory for 2010 > models? If that is the case I will need a screw that will securely hold the bracket in place..which screws to you use, could you take a photo for us? thanks!
Dan @ Duckworths - I have sent you an email re: order
If anyone else has experience of installing this please comment!
Post #100255 4th Jan 2012 12:54pm
Andy
I've never taken the trim card off, but I bet you could get your hand in and fit a nut to the inside where the bolt passes through? Someone might be able to confirm this 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #100259 4th Jan 2012 1:44pm
I've taken. The cover on mine off many times Sad
I reckon you could easily get your hand to the point to put a bolt in Smile
Post #100261 4th Jan 2012 1:52pm
sidmini
Kingpleb - how do you take the cover off please?
Post #100269 4th Jan 2012 3:18pm
1. Open upper tailgate.
2. remoce all the black screws from the top plastic trim(housing the release button) from the lower tailgate.
3. Press the release button for the lower tailgate once all screws are removed so as not to lose them.
4. Lower tailgate and remove the plastic upper trim from it.
5. Using gentle persuasion lift at one of the upper corners(closest to you as you stand at the tailgate) to prise the retainer clips away. Be gentle as they are fragile and i think about £1-2 each..
6. work your way acros the rest of the trim panel and spend a bit more attention toward the bottom due to the spring loaded cover that helps push it back down.
7. check all the retainer clips for damage and if needed replace them.
Refitting is the reverse of removal Very Happy
Post #100274 4th Jan 2012 3:41pm
sidmini
Thanks very useful info kingpleb! Thumbs Up
Post #100275 4th Jan 2012 3:57pm
