Home > Technical (L322) > 2010 REAR LIGHTS
This topic is locked: you cannot edit posts or make replies.  Down to end
oodathort
2010 REAR LIGHTS
If anyone has the Disco effect on start up of the rears flashing then I have the answer and only costs around £12.00 per side to fix I can supply a circuit board that will cure this if anyones intrested
Post #102945 22nd Jan 2012 2:48pm
daveo
what about the side light/ fog light issues V8 facelift Range Rover Autobiography 22" wheels.
Post #102947 22nd Jan 2012 3:02pm
oodathort
Hi what sort of issues regarding fog lights
Post #102956 22nd Jan 2012 4:06pm
daveo
well the side lights and fogs use the same led's but there is a voltage difference to make them dim for side lights and brighter when fogs are used V8 facelift Range Rover Autobiography 22" wheels.
Post #102957 22nd Jan 2012 4:17pm
oodathort
Yes sort of its correct that there is around 4 volts on the fogs all the time however the fogs and side lights are on seperate feeds so all you need is a relay on the fog feed
Post #102959 22nd Jan 2012 4:25pm
Ide like a set or two please if they work... i'll pm you my number...
Craig Thumbs Up
Post #102969 22nd Jan 2012 6:00pm
daveo
+1 i would like a set as well Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #102974 22nd Jan 2012 6:16pm
oodathort
Hi Guys not a problem but this is only the dissco effect issue if you need help with the fogs i can help you with how i got over the problem
Best Regards
Post #102980 22nd Jan 2012 6:38pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Or if you would like a kit to fix all your issues
And have a set of factory working 2010+ led lights
On any range rover from 02-09.
Then ask me. RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #103047 23rd Jan 2012 12:02am
oodathort
Hi what does your kit cost and does it encompass all issues
Thanks
Post #103068 23rd Jan 2012 7:32am
Jr-auto-electrics
Hi
My kits fix every single fault,
1. Fog light on permanently
2. Fast flash indicators
3. Disco lighting on start up and every 40sec after that
4. faults on the your dash read out (obc)
Same as above for the front
Minus the fog light fix. RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #103070 23rd Jan 2012 8:45am
oodathort
Cost ?
Post #103074 23rd Jan 2012 8:53am
oodathort, can you pm jr electrics re cost please... ... - .- -.
Post #103077 23rd Jan 2012 9:21am
Martin
Site Admin
Commercial Posting - i.e. using this site to promote or sell items - is NOT allowed unless you are a sponsor, via PM or otherwise.
http://www.fullfatrr.com/forum/topic95.html
Email sent.
Post #103118 23rd Jan 2012 11:48am
This topic is locked: you cannot edit posts or make replies.  Back to top
