![]() | Home > For Sale & Wanted > FS: Heated Steering Wheels |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
Dan,
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Super, not the flappy paddle will not work on yours, they need an elaborate mod to do so. |
I have paddles on mine and although they dont work yet they look good |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Anyone care to post fitted pictures? Looks like a nice way to freshen things up. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Here's mine. Can't recommend it highly enough, and I was an initial sceptic.
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
bump, price drop |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
I fitted one recently to my 05 facelift.. Simple install, only thing is the heat connection was slightly different so wouldn't just plug in, solved by just snipping off bit of plastic on the connection.. Well worth the upgrade feels really smooth and looks great. The heat is now evenly distributed all over the wheel and doesn't scald.. |
rich_959 Member Since: 13 May 2011 Location: East Yorkshire Posts: 64 ![]() ![]() ![]() |
STUPID QUESTION ALERT..........
i would say you can't remove them You can paypal direct using - www.paypal.me/duckworthparts
bump |
Yes they can be removed easily... Most retrofit them to their existing steering wheel like i did... All you would need to do is either use your rear top black plastic cover (to replace the flappy paddle when removed) or order the silver one from Dan... You cant see the rear covers when fitted, so i would fit my old black ones if i wanted to remove the paddles... Simply insert a flat head screwdriver and twist, the flappy paddle will unclip from the front cover and remove... Undo the little torx head screws holding the rear cover on the wheel first though! Craig ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
helpful as ever craig... |
got 2 left You can paypal direct using - www.paypal.me/duckworthparts
