![]() | Home > General > Piece of Junk Chucked it Again |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
Not forgetting the cold start engine squeak has been sorted too.. |
Well i did know they were going to fix the camera for nowt …
Anyhow anyone know the answer to the earlier question …..
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Was there any message about the smart key not being recognised?
No message at all , the car opened and closed remotely with the key during the 15 min period as i kept trying it …
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Does the FFRR use the same start button system as the Jags? There was an issue with faulty start buttons that were sending the wrong signals in new XJs - would randomly switch the cars off and unable to restart! |
TBH i don't know if they do …. ====================================
It's more than likely. A mate of mine had a faulty start switch and it was booked into the stealers for the next day. The day before was driving alone, engine randomly switched itself off (faulty signal) and wouldn't restart. Had to be recovered. Definitely get it checked! |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
I believe RRs wont attempt to start unless it knows the battery is capable of doing so, this is to prevent damage. Could the connections to the battery be loose? Next time try twisting the connections on the battery slightly |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
Nick, also, don't tell Mick that the faulty rear washer has been fixed for the sum total of 30p. |
We can always swap Mick |
I got the rear washer renewed before I traded it in , a full new washer arm assembly if he checks the paperwork I think it cost £135 incl labour from the dealers in Stirling .... About 7 months back ...
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Your tank of diesel will last forever in the TDV8 Mick |
That's true 47 as after one park heat cycle while waiting for recovery it will only use 1/2 a litre, though I bet the guys at the LR dealership will give it a good try when they get it running again |
