![]() | Home > Maintenance & Mods (L322) > Best replacement jack options to replace scissor jack. |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
Paddocks do a good trolley jack for about £35, but obviously not something to keep in the boot.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
some of the options you have are,
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
Looks like the bottle jack maybe an option then, I think the P38s had it as standard, I want something that enables me to change the wheels for winter/summer/offroading as well as for puncture replacement. Last time I used the foam can, the tyre was too gone due to a screw embedding itself in my nearly new tyre. Tom
i've covered my options pretty well i think,
Thanks for the info guys. Tom
| jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156
What about the inflatable bag that some use even off road when the ground is too soft ??
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
Send the wife to the gym to build up her muscles enough to lift the corner.... |
| 33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381
I'm with Scarey
| Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435
Any recommendations on trolley jack? Ideally low enough to fit under the Aston as well? |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Another option, get a used airbag suspension strut and use an airline fro
machine mart is where i got mine....3 ton about £80 .... ... - .- -. Y. O. L. O. . |
| L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19
Thefirst time I used the supplied scissor jack it buckled and I could not bring car down, had to drive it off and risk body damage. Bottle jack purchased from Lidol for £18 and it fits in the spare wheel compartment. |
| Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011
Make sure trolley jack has enough height, and also a low height when not jacked, to enable getting under suspension with flat tyre.
This is good but would need a plug of sorts for the other tailpipe on an ffrr...
