Home > Technical (L322) > HELP NEEDED DRIVERS DOOR WONT OPEN !! |
How many times did you try to lock and unlock the door within a minute ...... Dont do it any more than 3 times ........ |
4th Jan 2010 10:51pm |
l322 mark Member Since: 04 Jan 2010 Location: norfolk Posts: 4 |
i may well have from wot i see on the net it is the door lock that has failed .....but how do i open the door .... |
4th Jan 2010 11:33pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
Mine did this the other day. Not sure whether it's related to the cold weather, but I found that when I opened the door, it wouldn't shut. The door kept bouncing open. I had to get into the car, hold the door shut then hit the master lock button under the hazard warning switch. Then, the door wouldn't unlock and I ended up climbing out of the passenger seat! Works ok now. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
5th Jan 2010 6:02pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
will it not unlok with the key... V8 facelift Range Rover Autobiography 22" wheels.
5th Jan 2010 7:35pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3078 |
mark, This is caused by the door locking mechanism freezing inside. I had exactly the same thing last week. You need to get some WD40 type spray with a thin pipe attachment and spray inside everything - the key hole, the handle and the lock inside. Also, wipe round the rubber with glycerin or teflon spray to keep the rubber from sticking. It is wise to wipe round the main door frame with a cloth when it is warm and get rid of excess moisture and dirt which aids sticking. Mine was outside in -8 last night and opened no probs this morn. (PS as you can see from the lack of response on "landyzone" this is a far better, friendlier and helpful forum!) |
5th Jan 2010 8:16pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6356 |
Landzone?
5th Jan 2010 10:38pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 737 |
A week ago the driver’s door wouldn’t open from the outside anymore. After documenting I started dismantling the door panel, and after removing the foam padding I found that the cable that connects the door handle to the lock was broken. It is difficult to remove the cable through the tiny hole, but the most difficult part was to remove the round cable end that remained stuck in the handle. It is the second time a cable fails on me (the first was the hood one) and I find this really annoying, it’s either a design flaw or use of bad components. I also noticed that the cable was wet from the water that probably pours through the window seals.On such a pricey car it’s just intolerable, also because replacing it is not really easy. Anyway, I have to wait another week for the 13 Euro cable now... |
6th Jan 2010 7:35am |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
mmmm i had my cable brake in sep this year i swaped it over for a new one (your right the end was very difficult to get out), 1 month later the cable popped out of its seat but did not snap no probs since. i put this down to one of those things on a 8 year old car
6th Jan 2010 8:23pm |
im sorry i wont use that site again well this is turning out to be a strange one i think wot you are saying is right but its all a bit strange.....after a whole night of not being able to get in it , i went to it the next night and it opened !! so i opened ans shtut it about 6 times and it was fine ..so i locked it and the same problem happend wont re open !!!! .after loads of trys i gave up ,had a look at getting door card of but with door shut it would wreck it . so i left it again, tonight i go to it and it opens so i remove door card and it looks like there is water around the locking mech ..so i sprayed it with wd40 locked and unlocked .....all was working fine ....then it stopped working all together all the other doors lock and unlock but not the drives it does nothing ..but at least i can get in . so now wot is next to do could this be a fuse gone now ,my thinking is that a new mech is needed any ideas ......(thanks for all your help) mark |
6th Jan 2010 8:39pm |
As some of us found water all over cables and mechanism I believe this could mess with the oversensitive electronics of the car... |
7th Jan 2010 10:07pm |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 |
I have vaselined all my rubbers today!!!!!!!!!!!! If you have nothing nice to say,say nothing at all. |
7th Jan 2010 10:19pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3702 |
I have been having this exact same problem for two days now, it is -8 here in the bright sunshine.
8th Jan 2010 11:54am |
inkiboo Member Since: 13 Nov 2009 Location: Aubonne Posts: 80 |
And what about the Range Rover's rubbers? |
8th Jan 2010 1:50pm |
8th Jan 2010 2:12pm |
