Home > Maintenance & Mods (L322) > TD6 changing air and breather filter
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
How long will this take a novice (me) to do? I'll print one of the many online guides off just wondered how long it should take, and also anything to watch for
Post #108652 22nd Feb 2012 6:32pm
No more than a couple of hours, including tea breaks, should do it, if it is your first time at it and you have all the right tools and parts. .
Post #108654 22nd Feb 2012 6:46pm
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
All pretty straight forward apart from the back bolt that fixes the air filter cover. It's a PITA to get out, and even more difficult to get back in. The way to make this so much easier is to remove the rubber trim and a couple of nuts so you can take out the pollen filter housing. It's not as extreme as it sounds (there's probably something on the forum if you search), and access to the breather filter and the rear of the air filter is so much easier. I found out the hard way Rolling Eyes
Post #108655 22nd Feb 2012 6:49pm
mrblonde
Cheers guys
and is it worth fitting the newer 'vortex' typre breather filter (like they use in BMW's), or just fit the standard blue foam roller type?
Post #108657 22nd Feb 2012 6:55pm
Does this help?
http://www.fullfatrr.com/forum/topic746.html Discovery 4 HSE
Post #108664 22nd Feb 2012 9:02pm
mrblonde
bl00dy marvellous mr RRUK, many thanks!!!
Post #108667 22nd Feb 2012 9:16pm
its all in the wiki mrblonde.. Rolling Eyes ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #108668 22nd Feb 2012 9:29pm
Also here (for crankcase breather filter location)
http://www.fullfatrr.com/forum/post12326.html#12326 .
Post #108787 23rd Feb 2012 1:10pm
When you've changed the fuel filter before starting put the ignition on and wait approx 40 seconds until the tone changes on the fuel pump... That way you dont cane the starter motor whilst it builds fuel pressure to start...
Craig Thumbs Up
Post #108794 23rd Feb 2012 2:09pm
Renegade2
I followed the info on wiki doing mine for the first time and i did eveything including oil change, fuel filter, air filter, crankacse breather (i changed the whole valve) and it took me a afternoon. The back nut as stated is not the easiet but i put some cloth on the bumper and front and climbed in!!!!
Must admit i really enjoyed doing it but could not have done it with out the help of guides done by the guys on here so a big Thumbs Up to you all
Post #108923 24th Feb 2012 12:50am
