Home > Technical (L322) > Squeaky Rear Suspension ?? |
Luckyluciano Member Since: 29 Oct 2011 Location: Wiltshire Posts: 121 |
Yes I replaced both cables and had the joy of a squeak free car for all of about a week
4th Sep 2012 2:19pm |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
My local mechanic chappie is insistent it isn't the bushes and that it's an actual suspension component that's on the way out ... Not sure I believe him. May change bushes as cheaper option and see what happens. Will keep you posted. African Bush Junkie ... in London!
4th Sep 2012 10:03pm |
terex48 Member Since: 06 Feb 2011 Location: Scotland Posts: 8 |
My left rear damper is making a terrible creaking/squeaking noise . I sprayed wd40 and armour all up it , but I think it has a dust seal . Do I have to depressurize the airbag to remove the damper? 2004 Range Rover Vogue TD6
10th Sep 2012 8:32pm |
Are you sure it isn't the rose bushes squeaking? |
10th Sep 2012 8:44pm |
Well I was underneath it while my father was pressing down on the tailgate .I am going leave it a while to see if the WD40 will work in .I am pretty sure it is the damper. 2004 Range Rover Vogue TD6
10th Sep 2012 9:03pm |
Update.
24th Oct 2012 8:51am |
Petru Member Since: 23 Nov 2015 Location: Moscow Posts: 6 |
Can someone please specify which parts should be replaced?
15th Mar 2017 7:53am |
That's beyond my limited awareness I am afraid but there is an excellent how-to in the Wiki here ...
15th Mar 2017 8:46am |
Thank you for the link.
15th Mar 2017 10:24am |
