Home > Technical (L322) > Squeaky Rear Suspension ??
Page 3 of 3 <123
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Lucky, did you change the cable and did it sort out the squeak? Lubrication worked for around a month on mine but it's back with a vengeance Sad African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #139294 3rd Sep 2012 8:43pm
Luckyluciano
Yes I replaced both cables and had the joy of a squeak free car for all of about a week Big Cry
I can only think it is one of the bushes but the problem is which one??
I have figured out that if you do an emergency stop the squeak goes away for a few days Shocked Range Rover Autobiography 5.0SC
Range Rover Vogue 4.4 V8 SOLD
Aston Martin V8 Vantage
Post #139390 4th Sep 2012 3:19pm
DeRanged Rover
My local mechanic chappie is insistent it isn't the bushes and that it's an actual suspension component that's on the way out ... Not sure I believe him. May change bushes as cheaper option and see what happens. Will keep you posted. African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #139483 4th Sep 2012 11:03pm
terex48
United Kingdom 2004 Range Rover Vogue Td6 Alveston Red
My left rear damper is making a terrible creaking/squeaking noise . I sprayed wd40 and armour all up it , but I think it has a dust seal . Do I have to depressurize the airbag to remove the damper? 2004 Range Rover Vogue TD6
1997 Defender 90 300 TDI
Post #140531 10th Sep 2012 9:32pm
Are you sure it isn't the rose bushes squeaking?
Post #140534 10th Sep 2012 9:44pm
terex48
Well I was underneath it while my father was pressing down on the tailgate .I am going leave it a while to see if the WD40 will work in .I am pretty sure it is the damper. 2004 Range Rover Vogue TD6
Post #140538 10th Sep 2012 10:03pm
DeRanged Rover
Update.
Changed the upper hub bushes and the squeak is gone ... The mechanic had initially suggested that the suspension itself may need replacing ... thank God for this forum! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #147761 24th Oct 2012 9:51am
Petru
Russia 2007 Range Rover Supercharged 4.2 SC V8 Baltic Blue
Can someone please specify which parts should be replaced?
As far as I get I have to change 5K792B (RBK500220) and 5K792A (RHF000260)?
What about 5A638A (RGX000080), 5A638B (RGX000071) and 5A638C (RGX000060)? Are they a potential problem? Is it good to change them all?
This is quite detailed pictire below with detail numbers. I have identified part numbers below in brackets.
Post #431250 15th Mar 2017 8:53am
DeRanged Rover
That's beyond my limited awareness I am afraid but there is an excellent how-to in the Wiki here ...
http://www.fullfatrr.com/forum/post140711.html#140711 African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #431254 15th Mar 2017 9:46am
Petru
Thank you for the link.
Looks like he is only changed RBK500220 RHF000260.
Very useful he mentions bolt, washer and nut part numbers.
Post #431265 15th Mar 2017 11:24am
Page 3 of 3 <123
