Home > Technical (L322) > Key stuck in ignition lock |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
i think you might find its the mechanics underneath that need lubricating......i'm sure there's a thread or two on this on the forum .. ... - .- -.
22nd Dec 2011 8:44pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Wiki
22nd Dec 2011 8:59pm |
nikbarber Member Since: 16 Dec 2011 Location: Warwick Posts: 36 |
Thanks for the responses. I have just lubricated up the shifter mechanism and cycled it through PRND as suggested. Unfortunately now the key is completely stuck in the lock, and won't come out with any amount of jiggling!!! |
22nd Dec 2011 9:47pm |
Have you tried your foot hard down on the brake pedal at the same time as the gear selector is in the P position to release the key ... ====================================
22nd Dec 2011 9:50pm |
that means that your not engaging park ..if you play about with it a bit more you should [hopefully] get the key to release.... ... - .- -.
22nd Dec 2011 9:52pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
The cable that connects the gear lever to the ignition (in green) pointed to by red arrows:
22nd Dec 2011 11:08pm |
Thanks Joe90, you were spot on! Lubricated up the (green) cable and it all seems to be working fine now. |
22nd Dec 2011 11:20pm |
PS. Why is that cable soooooo long? |
22nd Dec 2011 11:26pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
On the gearstick end of the cable there is a large fork (that stops your shifter moving when your key is out). If your key sticks again lift the leather gear surround and lift or push down the fork and it should release your key. If this works then look at the image again and to the right of the red arrow (pointing down) is the fork i mentioned with a pin that should move freely (with a spring one side and a retaining clip the other). The fork should move independently of the pin, you will probably find your fork and pin have corroded together so you should hold the end of the pin (the spring end) with some grips and lever the fork in the opposite direction spraying with WD40 or alike and keep working it for a while until loose...
23rd Dec 2011 12:51am |
wiki'ed ... - .- -.
23rd Dec 2011 9:31am |
Stan
23rd Dec 2011 10:02am |
CHANDOS Member Since: 03 Dec 2012 Location: Taunton Posts: 16 |
The ignition key became progressively more difficult to remove from my 2005 Autobiography. Examining it I noticed it was not returning fully to the at rest position. The local dealer was quoting £850 to replace the locks. I found this thread and gave it to the village garage with the car (key completely jammed in now).
6th Dec 2012 1:24pm |
Glad you got it sorted, Chandos!!! 2005 FFRR Td6 Vogue
8th Dec 2012 8:19pm |
